Brakes SlipWhen Braking Hard
rrb6699
Orlando FL
yesterday iIwas driving and had to stop fairly quick for a light. heard a noise and the truck Braking wasn't really stopping. i pumped the brakes and it slipped again. after that I Imade sure to brake gradually and had no issues. I pulled the left front wheel and the brake pads are about half worn. shouldn't have slipping. the right one looked ok the last time i pulled it a couple weeks ago. also half worn.
could a bad bearing cause a slipping? I've ordered new inner/outer front bearings anyway.
it's a serious issue since if iIneed to brake hard, it has to stop.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Pull your drums and check that.
Sounds to me like you have something broken in the rear brakes and it's shifting causing the noise and stopping power loss.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
following....... hope you solve it soon !
rrb6699
rrb6699
Orlando FL
sorry it's definitely in the front brakes
bearings are fairly inexpensive. I'm going to order front & rear bearings. replacing those may uncover some issues. could it be all iIneed is brake pads. these are about half worn or more.
jessyj
abbotsford, bc
If the rotors aren,t wobbling then its not bearings. Pull the rear apart and have a look. It could be the abs doing its job.
rrb6699
rrb6699
Orlando FL
abs on a 96? didn't think about that, but, it didn't sound normal to me and it was like there was no stopping ability. i thought I Iwas going thru the light really.
I'll check the rotors to see if I can move them. it took a hard brake though for it to happen.
it felt like if my foot didn't pump the pedal it wouldn't have stopped
jessyj
abbotsford, bc
Ya the abs on these old trucks isn,t what it supposed to be. When you slam on the brakes its feels like you won,t stop.
rrb6699
rrb6699
Orlando FL
Well, it's unsafe in my opinion. How do you disable it? Is it a fuse or another way to disable it. I want hard brakes when I push on the brakes! I don't mind locking up tires if I need to.
i grew up with power & even non-power brakes. (still have a '72 beetle) & I can control the car Braking better without any "help". I'm gonna try pulling the fuse for ABS and give it a test because I think it isn't working properly and is clumsy at best being an old abs system. hopefully, that is all I'm going to need to do.
