BullRing in bed hooks installed
chrisbh17
Question - is that the factory spray-in bedliner?
I noticed a review on Amazon where someone said the inner rings do not fit over the factory spray in liner. Yours seem to fit OK, you mentioned you have to trim some of the bed liner...is it bare metal under there? Or painted?
Didnt want to remove bed liner and make rust in the future.
Thanks.
-Chris
BWL
Embrace the skeptisism
BC Canada
I have the top rail ones on mine. Back ones is an ooen hole, but I trimmed the sleeve. Front you have to trim a hole in the plastic, but not the entire cut out. The drivers to passenger side cut out lines are good, but front to back is about 1/2" inside the cut out lines on both edges. Did it with just an exacto knife. Allows me to tie things down on top of the tonneau or bigger items that make it hard to get to the factory tie downs. I also have a custom set of rails that skeleton the fender wells that are solid and provide numerous tie down points as well as a way to use a u lock to keep my bikes from being stolen easily.
I have a spray in RhinoLiner in my bed and the BullRings that go inside the bed. The BullRings for without having to trim away the liner and I know it's thicker than the factory spray in bed liner. I loosened the screw till it almost came out then was able to get them in place.
T
Truck Fun
Missouri
2021 Classic
Thanks.
-Chris
I have the factory spray in liner. I just had to remove some overspray that had extended out into the hole some. Probably could have just tried pushing harder also.
T
Truck Fun
Missouri
2021 Classic
...I also have a custom set of rails that skeleton the fender wells that are solid and provide numerous tie down points as well as a way to use a u lock to keep my bikes from being stolen easily.
Could you post a picture of your custom rails?
