Burnt out headlight
jljbtm
I have a burnt out headlight in my 2011 Laramie and just thought I'd ask the group if one bulb is better than the others?
Sent from my SM-N910V using Tapatalk
abouttobeglue
I just put a set of Philips Xtreme vision h11 and 9006 bulbs in my 2016 ram,made a huge difference in night time visibility, brighter, a bit whiter than stock, and farther distance.
jljbtm
jljbtm
Thx. I'll try those!
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
There are better standard bulbs like Sylvania if you're tired of having to use your fog lights at night to see the lane markers right in front of you.
There is also a much brighter bulb used as a high beam in some vehicles with the same receptacle plug, but with a 1/4" protrusion you have to snip off . I forget the numbers, but if you pull the correct one off the hook, and then look for the nearest match you'll see what I mean. That's less expensive for two than the Sylvania's. Cheap-guy life-hack!
jljbtm
jljbtm
I seem to have both the high beam and the low beam burned out on the left side can't be a coincidence?
