c code 23
C-Code 23 53 i already know that 23 Headlamp switch input circuit open. And i know that 53 is how many key cycles have passed since the code came up. Im just needing to know if there's anyway to clear the code i have taken the battery cables off to reset the codes but the code still remains on there. If there's any other suggestions id appreciate it.
HemiBabe
DFW
Doing a quick search, I found this:
"If there is not problem it will eventually go off, use your tuner or scan tool to clear them, or you could also have Autozone or a car parts place clear them."
