C4B/NHTSA 24V-896
KC15842
So Cal
Cummins
C4B/NHTSA 24V-896
IMPORTANT SAFETY RECALL
Hydraulic Control Unit (HCU) ABS
This notice is sent to you in accordance with the National Traffic and Motor Vehicle Safety Act. FCA US LLC has decided that a defect, which relates to motor vehicle safety, exists in certain [2017 - 2018 (D2) Ram 3500 Pickup, 2017 - 2018 (DD) Ram 3500 Cab Chassis, 2017 - 2018 (DF) Ram 3500 10K Lb. Cab Chassis, 2017 - 2018 (DJ) Ram 2500 Pickup, 2017 - 2018 (DP) Ram 4500/5500 Cab Chassis] vehicles. RECALL DESCRIPTION The brake hydraulic control unit (HCU) on your vehicle [1] may be susceptible to failure or malfunction which may result in a reduction or change of Anti-Lock Brake System (ABS) /Electronic Stability Control (ESC) /Traction Control performance. A failing HCU will initially result in the intermittent loss of ABS/ESC/Traction control progressing to permanent loss. The loss of ABS/ESC/Traction control may cause a vehicle crash without prior warning.
I've been on a list for an extended period of time and never get updates. I've reached out several times with no progress. What's it take to get a SAFETY RECALL addressed?
angelodimorte
FL
hello new to this forum, I have 6.4 2500, I am at plaza ram in Inverness, fl, I am currently getting the recall performed, per parts department, they have 3 in stock. I was in for oil changes, they told me they have the part. Just fyi
