Cam install
01rammer1500
Im in the middle of doing a complete tune up to my new (to me) truck. I just did the hughes engines plenum upgrade kit, and i did plugs, wires, cap, rotor while having the intake off.
I was wondering if anyone has installed a cam with the engine still in the truck?
I still have the radiator out so it would be easy, i would think. But i dont want to remove the heads if possible.
When i built my dayly driver, i pulled the whole engine apart. So i have no experience with trying to keep the bearings and such in place.
The truck was going to be a parts truck because of how rough the body is, but after installing new body panels, i cant see why not have 2 bada** rams?!
Any advice would be greatly appreciated.
Sent from my LG-D850 using Tapatalk
MagSport
South Carolina
You should have enough room to swap cams with the rad out. if you do or don't though, go ahead and do a double roller timing set.
Merc225hp
NA
truck
gas
A/c condenser must be moved ss well
01rammer1500
How would i go about keeping the valves from falling in to the cylinders? I have to upgrade my springs.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
The tool that screws into the spark plug hole or you can stuff rope into the hole
Thundervee
5.9 Gas 5.7 hemi
There's a tool to screw into the spark plug hole, then you hook up air to it, that will keep the valves from dropping in while you change your springs.
