Camber and Vibration Issues w/ Lift
ryancorcoran6
North/Central Illinois
I have a 2012 Ram 1500 4x4 with a 6 inch RCX lift and a 3 inch body and adjustable Bilsteins shocks up front, I also have 37 inch tires with 17 inch rims with little offset maybe -12ish but I also have 2 inch wheel spacers, my front tires have worn greatly on the inside on the front end even though the tires were just recently aligned within the past 3000 miles. Do I need to get them aligned more often or is something such as tie rods being bent or stressed too much due to the spacers? Also I have ALOT of vibration in the steering wheel at anything above 35ish miles per hour. There was no vibration or anything until the body lift, adjustable bilstein shocks, and spacers were put on a little over 3000 miles ago. These issues came around very soon after and have gotten worse and worse. Any input helps, thanks!
