Can 37s fit with a -25 offset wheel and 5" leveling kit?
Donald Wantz
Ohio
Hey guys. I have a 2015 ram 2500 with 5" rough country leveling kit on 20x10 mayhem warrior wheels with a -25 offset and kenda klever R/T 285/55r20. So, the question...
I wanted to upgrade to 37x12.5, do ya'll think they will fit? I'm ok with trimming if I need too, just curious if someone has done this before or tried and failed this before.
I've seen a lot of videos and articles about needing a positive offset and narrow tires, but nothing about 12.5" wide tires on -25 offset rims.
Thanks guys
Sent from my SM-G973U using Tapatalk
Ohio5pt7
Ohio
Have you check custom offsets?
Sent from my KYOCERA-E6920 using Tapatalk
Donald Wantz
Donald Wantz
Ohio
I'm looking at there website, do they have a calculator somewhere to figure it out?
Ohio5pt7
Ohio
You can search thier gallery. If the level is common chances are if it's possible you will see it on there
Ohio5pt7
Ohio
By what I see you'll be golden
Ohio5pt7
Ohio
No problem glad to help
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Thanks guys
I believe it was the lifted section but 2500's trimming will be at the back of the cab instead of the front bumper. You should be good though. Had a neighbor with a leveled 2500 stock rims and 37's. Ridge grapplers.
MartyZ
Lake Orion, MI
2500 5.7l Hemi
I have a 2014 2500, 5" front 3" rear. I am clearing (Barely) 37 x 13.50 R20s with a -24 offset. And yes, you will need to trim the body at the cab front where it meets the wheel well. Its not bad but if you don't you are gonna chew up your tire on your first turn that has a bump (aka my driveway) If you want I can post some pictures of what was trimmed and the clearances I have currently. But yes you can fit them. The rears have clearance for days. the fronts are fine if your wheels are straight or completely turned, its the point right before max turn that gets hairy.
Nicholas Lozano
