I have a 2000 dodge ram 1500 with a 5.2 in it. I have an issue that I can't seem to get a good answer too. Whenever I turn to the right my right front tire rubs on the lower control arm where my strut is bolted. It is wearing away at the tire. The truck has new struts, ball joints, tie rod end, sway arm, bearings, etc. Basically all new front suspension besides the springs all within this year. I also just recently had an alignment done and it still rubs. Both tires rubbed prior to front end overhaul but now it's just the driver side. Would you have any idea what is causing this???
