CAN BUS Questions
ScottOswald
Midland, TX
Good Morning
I'm looking for info or help related to the CAN BUS system. I am wondering if I can use the Parking Sensor buttons as a switch? Currently I have my park sense module unplugged and disabled as I installed aftermarket bumpers. So those buttons are not being used. I'm wanting to know if it is possible to use these to run something like aftermarket lights, or another auxiliary relay? Any help is much appreciated. I am pretty ignorant on the CAN BUS system. Thank You
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Good Morning
I believe the button module itself has the commands stored so no matter what, when pressed it will send the park sense commands. You can however buy a new switchbank with auxiliary buttons and park sense deleted.
The only way to make this work the way you'd like is to have some sort of CANBUS adapter in between that intercepts the park sense signal and translates it to some custom command you'd want.
ScottOswald
ScottOswald
Midland, TX
That would work. I am struggling to find, if possible, a way to do that. I have the wiring diagram for the module itself.
ScottOswald
ScottOswald
Midland, TX
Is there any sort of adapter you are aware of that would work in this way?
I have thought about the factory aux switches. Currently that's not an option.
Appreciate the info.
ScottOswald
ScottOswald
Midland, TX
This maybe an easy way for you to get use out of that area.
I'm thinking about going this route. I don't want to lose my heated/cooled seat buttons. I know they are in the Uconnect as well. Just prefer the buttons.
ScottOswald
ScottOswald
Midland, TX
Was curious if I can somehow use the pink (CAN C +) and yellow (CAN C -).
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I know @Roman217 has done something similar for a different application on our trucks (HVAC commands for 12" UAX in 4th Gen trucks). He might be able to sell you one with modified programming for your application or talk you through developing your own? Try sending him a PM.
ScottOswald
ScottOswald
Midland, TX
Awesome! Will PM him now. Thank You sir!
ScottOswald
ScottOswald
Midland, TX
Was going to go ahead and order this. Not shipping to the US right now due to tariff's. Dang!
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That's a great price, note though the switchbank itself is not inlcuded.
wrench78
Air Force Law Enforcement
SE PA
2022 2500 Laramie
6.4L
Ya, you can get different switches from here, when ever they start shipping again.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Thanks man, I'm bookmarking this...if you're keeping track be sure to post when they are shipping again!
