DaveRamsey
I have been plagued with this oil leak. I was sure it was oil filter adapter seals. Then after really cleaning the sealing surface, and using black rtv, I replaced the whole adapter. It actually appears that the oil is leaking from the top side of the block side “flange” / mounting point for the adapter. It is a solid stream about 1/16” thick that pours off when running. There is heavy corrosion on this motor. Is it truly possible oil is coming out of my block here? TIA
