Hemi4905
@pacofortacos - Wheel looks solid aluminum but interesting fact that the chrome clad pops off and leaves the right diameter for the spare drop down bracket.
You realize that the spare tire is the same diameter as the oem 20s, right? 17" rim or not doesn't matter. They use the 17s because 17" steel rims are the smallest that fit over the caliper, and 17" rims and tires are cheaper than anything bigger. If anyone is worried about corrosion, drop the spare once or twice a year, inspect it and give it a good coat of wd40 or protective film to keep it from rusting. Also worthwhile to spray the winch cable to keep it from rusting solid.Thanks but I just wouldn’t feel safe towing a trailered car knowing my spare is a 17” when I’m on 20”s.
I think the bigger issue is the tires temporary designation, as well as load rating when pulling a trailer. It is better to have a full size matching spare given the option.You realize that the spare tire is the same diameter as the oem 20s, right? 17" rim or not doesn't matter. They use the 17s because 17" steel rims are the smallest that fit over the caliper, and 17" rims and tires are cheaper than anything bigger. If anyone is worried about corrosion, drop the spare once or twice a year, inspect it and give it a good coat of wd40 or protective film to keep it from rusting. Also worthwhile to spray the winch cable to keep it from rusting solid.
235-85r17 is equivalent to a 33" tall tire, just a narrow 33 that fits under the bed without hanging down too far.
As for the original problem, I'd see what would need to be trimmed on the bracket before modifying the wheel.
You could make a new bracket from new material.Modifying the bracket to fit through the small chrome clad hole would make the bracket too weak.
Most trucks with 20" wheels have 17 or 18" steel spares. If you have a wheel that the center axle hole is too small you should NOT be using that wheel anyway, not all RAM wheel cross fit to all other RAMS. Stay with a correct cneter hole size and be safe.I am sure you can do that , but if you do you might off center the wheel and then introduce a vibration if you ever have to use it. Or you can go to the junk year and look for a truck that has the 20s on them and take the spare tire holder from it.
Why not, its just a smaller rim size, the tires are still the same height.Thanks but I just wouldn’t feel safe towing a trailered car knowing my spare is a 17” when I’m on 20”s.
My 2010 Sport w/factory 20s has a steel 17" factory spare.
And its called an emergency "spare" for a reason.
Because the temp spare cannot handle the load of a trailer, esp. if it is on the rear.
The stock temp spare is also a bit too short for 20's but it is meant to cover the stock 20's and 17's.
It is 32.4" tall vs. the 33" for the 20's. It will work but there are better options.
Like the 32.7" for my LT285/70/17 spare tire on the stock aluminum spare rim
Can handle any load I throw at it and is a perfect size for a slightly worn 275/60/20 tire - and most flats occur on worn tires, not all but most.
Craigslist is a good source for cheap chrome clad 20's.
Now you got me wondering about two things for the morning; do I have a 20" wheel on my '13 Sport or a 17"? But, do I want to get soaked looking into this. It's supposed to rain for the next 6 days. LOLMy 2010 Sport w/factory 20s has a steel 17" factory spare.
