Can I reset the dashboard service indicators myself? Ram 2500 2022
chovyfu
California
My battery got drained. It didn’t start the first crank but did on the second. However now every dashboard service indicator light is on and nothing works on the dash.
I have an appointment in a week with dealer but I’m wondering if there’s someway I can reset the dashboard myself.
Ram 2500 4x4 2022. 6.4 gasser
Also curious if driving it is a problem until I get it fixed
C
chovyfu
California
Any guides online? I’ve never used one. Also I read that you can unplug the battery but I haven’t tried this.
2020PW
East coast
First fully charge the battery. Disconnect the battery for 30 mins and then reconnect it. The low voltage of the battery is causing all the lights.
C
chovyfu
California
How can I tell when the battery is fully charged? I drove it for about half an hour and it starts up fine. The meter on the dash is in the middle but when I start it it goes down to low briefly
2020PW
East coast
Use a multimeter while the truck isn’t running. If you think it’s charged disconnect the terminals and wait then reconnect them.
C
chovyfu
California
Do I just need to disconnect one terminal or both? If one which one?
C
chovyfu
California
Is it ok to drive it with all the error codes active?
2020PW
East coast
As long as the check engine light isn’t flashing you’re good.
C
chovyfu
California
It’s not flashing but it’s on. All the other indicators are solid on. MPH or brake assist lane keep assist any digital enhancement and cameras are not working though.
Blinkers wipers and engine work though
2020PW
East coast
Flash check engine is the only don’t drive condition. It means miss fire, owners manual will confirm.
C
chovyfu
California
So one problem still remains. When I start my engine I get a warning that brakes need to be serviced. Anything I can do for this myself?
Kickboxer
ND
5.7 Hemi-non-Etorque
Get yourself a battery charger. Everyone should have one in the garage.
A basic 2-10-50 automatic Schumacher is very handy. I have 3 chargers
and use this one the most. It will shut off when the battery is charged.
turkeybird56
Central Texas
Got me a Sears 2, 10, 50 Start (with AGM setting) in garage, LOL, just in case. Use on Stock trailer battery, sometimes lawnmower, and sometimes I just cheat and use my MC tender on trailer or the mower, lol.
1 MEAN66
Waterford NY
Hemi 5.7 VVT-MDS
Time to start buying tools. Battery testers at Harbor freight start at $2.47. On the first page (i just typed in Battey Tester at Harbor freight) they get more expensive ( in the $70s) but are still something will will use in the future. Get something descent.
They also haave battery chargers - with and without maintainers and Scanners
Bob_M
West of Atlanta
3.0 Hurricane SO
One, I do the positive.
NO NO NO NO
On a negative ground system, the negative battery terminal cable should always be disconnected first and reconnected last.
If your socket/wrench/pliers/whatever you're using to loosen the clamping nut at the positive terminal contacts any metal part of the chassis it will cause a short directly through the tool. Automotive batteries have a couple hundred amps and will melt a wrench.
Use a voltmeter and measure from the positive battery terminal to any metal in the area, that voltage - with all the amps - will be flowing through whatever tool your using.
Conversely, use the meter and measure from the negative terminal to any metal and you will get 0 volts, which includes 0 amps.
Disconnecting the negative battery terminal breaks the circuit back to the battery and there will no voltage or current flow from the positive terminal to the chassis. You can verify this with a voltmeter after disconnecting the negative battery cable.
Now, if you're working on a rare, very rare, positive ground system the above will be reversed. But with 99.9999% of the vehicles on the road being negative ground the above is true.
I learned this in High School Auto Shop in the '70s. Never forgot it.
Bob
