Can this be rigged?
reddot
reddot
Wolf Point, MT
5.9 cummins
so you assume a grounded switch will do it?
MADDOG
Living in a Firepit
6.4L HEMI
And if this proves not to work, check NAV-TV
NAV-TV
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Look on YouTube they show you how. I did it to mine. You use a relay to fool it.
Droid Incredible 2 on the move!!!
EOD_Tex
Central Arkansas
2014 Outdoorsman 4x4
I had to do the same thing on a Pioneer I had. It had a gyro of some sort inside the unit (which is why a ground isn't good enough) and the relay went to a set of pins on the back of the unit. Since that hassle, I decided to switch to Kenwood in future in-dash GPS's, which is easily groundable and has Garmin maps.
reddot
reddot
Wolf Point, MT
5.9 cummins
Ive had a single din flip out pioneer for years. Just got a second hand kenwood double din. Its fin I guess I just miss the setup of the pioneer and the full 7in screen. The link to the bypass on ebay says it for the unit im looking at so I figure it should work. I do kinda like the switch so I can turn the function off in case I get pulled over and questioned about it.
