Nicholasmcnulty
- Oct 27, 2015
- 4
- 2
- 2012
- Hemi 5.7
Hello forum, this is my first post. I have a 2012 1500 Big Horn Crew, to which I attempted to add an amp/sub. The radio is the RES 130, with no factory amplifier. I pulled the radio and piggybacked my LOC on the rear speaker wires of the factory harness, then tested. The radio came on, but the volume knob did not function and there was no sound. Here is where the Halloween spookyness comes in: I pulled the LOC off and got full control of every function of the radio (except AM/FM), but only for 3 seconds. I timed it... 3 seconds on, 2 seconds off, repeat. The AM/FM has never worked but I don't care about that anyway.
Troubleshooting so far:
IOD fuse pull
Pos&neg battery unhooked for 30min
Computer reset outlined here: http://www.ramforum.com/f44/4th_gen_pcm_reset-17703/#post327586
Checked for shorts behind the radio
Tested each speaker
Tested each wire of the harness with multi-meter
It seems as if the CANBUS did not like the LOC and knows it isn't there now, but it's stuck in a "check-and-see" loop with the radio. All other interior/exterior fuctions that run on the CANBUS are unaffected and working properly.
I hope I am not leaving anything out. If anyone can help or offer advice or knows exactly how to resolve this I am all ears. I should note that I am not interested in going to the stealership at all unless a Chrysler mechanic responds to this post saying that a flash or something will definitely fix this. I also have a new radio / PAC adapter / harness etc picked out to replace the RES 130 but I won't pull the trigger until I am sure the issue won't persist across radios.
IOD fuse pull
Tested each speaker
