Can't add tow mirrors?
Musclemckeester
Houston, TX
n/a
n/a
That's definitely BS. I know 5 people with 1500s and tow mirrors (including myself) and have had no problems. Next month I will have had mine a year (thanks again Butch!).
D
deerenwr14
Dartmouth MA
cummins 6.7 high output
The ones I have on my truck now have all the options turn signals puddle lamps heated and have the chrome face on them. I have a 2500 cummins larime longhorn So I would like the same options but in the tow mirror
quietpeen
2021 TRX
Hellcat
No thank you...LOL and holy **** it has been almost a year
the month that they were on my truck i had no issues
06Stang
I hope this isn't the case. I work at a Chrysler dealer and wanted these mirrors. I'll ask around.
D
deerenwr14
Dartmouth MA
Well I just bit the bullet I found a set of tow mirrors on eBay the exact ones I wanted d
So I bought them. I'll be able to tell you in the next couple weeks what the outcome is. What's the worst that can happen I'm still under bumper to bumper warrantee right?
ncgrl1
Cajah’s Mountain NC
2020 RAM LongHorn 4x4
I put them on my 2012 1500 Express about 6 months ago. They work fine. Only thing that doesn't is the puddle lights and turn signal lights.
jlb
MT
CTD
You could wire a relay off your dome lights or something for the puddle lamps, since the domes come on with your fob, then your puddle lamps would too, and add a relay from your blinkers to get it ALL working which would be pretty sweet.
relliK
NCR
3.0 Eco Diesel
Question
Is it possible to get them added as an option at the dealer and have the functionality?
Musclemckeester
Houston, TX
n/a
n/a
You won't have a problem. I'm 2 weeks short of having mine a year, I think you'll be fine.
Regarding your warranty, if it didn't come from the factory with it, they don't have to cover it.
D
deerenwr14
Dartmouth MA
If I switch the mirrors back to the stock ones before I bring it in they will cover it
Reactions: jlb
jlb
MT
CTD
Depends mostly on the wiring. If there is a factory pigtail there the relationship of the mirror to the trucks wiring system is probably the same as a truck that has them and just needs a reflash so the controlling unit has the software to run them. However if the door module thing is true the pigtail is probably part of the upgraded module which would require that to be changed as well.
Just crawl under there and do a little wiring of your own lol. It's all hidden anyways so just make sure you do it right, and no one will ever know lol
harr118
where did you guys get ur tow mirrors?
jasonjsla
