Good morning,
I remote started my truck before leaving my house. The truck shut itself down less than a minute after starting. I got in the truck to leave and found a CEL. Started looking for things that seemed odd and the only thing I’ve noticed is that oil pressure is much higher than normal. I had a broken valve spring repaired last year around Valentines Day. Since then my normal oil pressures have been around 23 at idle and around 50 at speed. This morning my pressure appears to be around 65 at idle and around 89 at speed. I have not had a chance to check codes and everything seem to be running great. I do not have a way to check actual oil pressure so I’m relying on the instrument panel.
I appreciate any help y’all can offer.
