Barry Phillips
Have 4 inch zone lift. Going to add bilsteins at 2.1 upfront and upgrade rear shocks while I’m at it to Fox 2.0. Anyone recommend to change UCA’s while doing this!?
I agree the shop that did my level said I didn’t have to but if you can it’s peice of mind I went with carlis but have seen lots positive comments on mevotech?Can’t hurt
Rough country or zone. Mevotech are stock replacements. You need something to properly realign the ball joint angleIs Mevotech MS251057 a good option? Any other options y’all recommend? Thanks guys
Zone are definitely your best bang for you buck. I've ******* about them couple of times in 2 years but in retrospect given the number of miles and abuse i've put them thorough i see no reason for me to complaint about them. No maintenance, tough frame and can take a beating for sure even with 37's. If you want a little extra flex (You need extended travel struts) you can try the JBA ones and they're just a few buck extra.
Have you tried a different alignment shop and purposedly asked them to set your caster at 5* on both sides? Some techs are lazy and don't want to spend the time doing it right. You won't get the same value on both sides for some unknown reason to me but one side will be 5 while the other goes to 4.7 or so. Then they can set camber to 0 or slightly neg to -0.2 on both sides.I always forget to measure/take pics since it's not top of mind, but the downtravel with the King's/JBA's is retarded for just being control arms and C/O's. They don't seem to give you as much castor as the Zone's though, but that hasn't been an issue for me on 35's.
I think Revit has that same issue with his CST Uniballs. He mentioned he has tried to get his caster up to 5* but the shop told him wasn't possible.I've gotten close before in the low/mid 4's before camber started getting out there. The truck won't ever see 37"s unless it's re-geared so it's eh for me with the travel they give you, I knew going in they wouldn't go as high as some of the others.
