Change your rear diff oil if you haven't yet and clean those lockers!
DParenti547
Tulsa
Looks like AMSOIL has 75w-85 now.
I wonder if Banks will still recommend AMSOIL 75w-90...
Lynaugh
LI, NY
Sorry to resurrect an old thread and please excuse my ignorance haha
I was looking to change the fluid in the transfer case and front/rear diff this weekend and have been trying to do a bit of research before so. I see that almost everyone says they use 75w-90 in the diffs with no LS additives but from what I see, the OM and Amsoil recommends 75w-85 w/ additives. Just making sure I get the correct fluid. (for a 21 PW) Thanks!
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
If you have 11.5" dia. rear ring gear, the only manufacturer I'm aware of is AAM. If it had Trac-Rite all gear torsen differential, then it does not need LS additive as the manual says. It is beneficial not to have LS additive because it slows torsen gear lockup when a wheel is spinning.
The only axle gear lubes I found were MOPAR 75W-85, Red Line NS 75W-90, and Mobil Delvac 1 75W-90, which is what I use in mine.
Lynaugh
LI, NY
I see, I guess the owners manual and the vehicle look up (like on Amsoil's website) are pretty generic as you can only search year, make/model and engine, but I do appreciate the help, thank you!
joesstripclub
Kansas City, MO
2021 2500 PW
I went with Mobil Delvac as I needed non-additive gear lube for my car as well. Summit racing had a good price and I think you got free shipping at 3 bottles at the time.
There is also Castrol Syntrax but its a little more expensive and harder to find.
HEMIMANN
Minneapolis, MN
I called Amsoil and talked to their Rep. This was several years ago. He said all their axle gear oil contains LS additive.
I also called Mobil and they said Delvac has no LS additive. Red Line website says their NS gear oil has no LS additive.
Gendeu1
