charonblk07
- Mar 14, 2013
- 4,056
- 2,088
- Location
- Calgary, Ab
- 2009
- F1-A forged 349ci
I'm officially going with the battery relocation, hopefully in 2 weeks if the weathers good. The plan is to use welding cable from the local supply shop as it tends to have a higher strand count and remain flexible in stupid cold temps out here. I will crimp and solder every connector and just ordered a 10 ton hydraulic crimping tool for $45, as long as it survives this job it's money well spent.
Dual Optima Yellow Tops relocated to the tool box in the bed, wired in parallel w/ 1/0Ga, no solenoid
1/0Ga cable from the alt to batteries w/ 300A fuse (I've blown 250A fuses here before)
1/0Ga cable from batteries to Amp distribution block
1/0Ga cable from batteries to Moroso 74102 power shut off switch in the roll pan
1/0Ga cable from shut off switch to (1) 1/0Ga to (2) 1/0Ga distribution block
1/0Ga cable from distribution block to starter
1/0Ga cable from distribution block to (1) 1/0Ga IN to (3) 8Ga OUT distribution block
8Ga cables to fuse box, auxillary fuse box breaker, and spare
Grounds:
1/0Ga engine-frame
(2) 1/0Ga battery-frame
Here's the battery bracket that I'll be using. I plan to paint it black before install and use stainless hardware.
I debated using one Red Top and one Yellow Top but I've decided I really don't want to have a solenoid in between the two like I had originally planned. This will give me a much longer off-key run time and shouldn't cause issues with the charging system. I do forsee requiring an high amp output alternator upgrade in the future, but we'll see what happens with the JL HD 900/5s and (2) 12W6-V3s. I don't like capacitors, so I won't be using any in this build.
Grounds:
1/0Ga engine-frame
