check engine light on and scan tool see no errors??
cheechman
magnum 5.9
Help me please... my dash tells me p0320 when i flick the key on 3 times but when i connect obd2 scan tool it does not see anything wrong and i cannot clear the error??
Truck cranks but does not start.
I ordered a crank position sensor and will change it as soon as i get it But how am i going to clear that error code if the scan tool does not see it?
Will it clear itself once i put in new crank sensor?
Thank you very mch for your help in advance guys its very appreciated
Dany
hemihustlin
Lower Southwest Quebec
What kind of scan tool are you using? Sometimes there are codes only a snap on or mopar scanner can access/clear
C
cheechman
magnum 5.9
I am using the blue obd2 scan tool from canadian tire and i also tried the bluetooth cheap ebay scan tool
C
cheechman
magnum 5.9
Problem solved guys. I received my sensor changed it and the truck started right away and check engine light (p0320 code ) cleared itself.
Symptoms i had with my defective crank sensor was rpm dropped to zero while driving truck. It was stalling at 100km/hr on the highway and sometimes start right up by itself or just wont start again and i had to tow it home... sometimes i was ok for a whole month and other times it was stalling everyday.
Thanks for your help
