Chrysler 9.25 Leaf Spring Perches
Braeden Clark
Williamsport PA
5.9l
I am trying to buy new leaf spring perches for my 2000 Ram 1500 with the chrysler 9.25. I am having a hell of a time finding the dimensions of the stock ones. I think the stock leaf springs are 2.5 inches wide and the axle tubes 3.5 inches in diameter but not sure. Is that all I need? Any help? Any links for replacements? Thanks
Fast69Mopar
You are correct with your measurements. The 9.25 axle tube diameter is 3.50" and the spring width is 2.50".
Here is a link to some new ones...
Braeden Clark
Braeden Clark
Williamsport PA
5.9l
Thanks man. Extremely helpful. Another random question, is there weatherstripping connected the doors of these trucks? Mine has weatherstripping on the body, but is there some on the door as well? Mine doesn't have any on the doors.Asking because my doors leak and this truck is new to me. Thanks
Fast69Mopar
Yes there is weatherstrip on the doors. If you don't see any in the doors then I understand why you have wind noise. It's probably pretty bad too.
Braeden Clark
Braeden Clark
Williamsport PA
5.9l
Yep. Wind noise js also very noticeable. Guess I will look into fixing that. Definitely before winter...
Braeden Clark
Braeden Clark
Williamsport PA
5.9l
One last question. Do you know of any aftermarket rear shock mounts for the rear end? I am swapping in a 3rd gen 9.25 and it's kinda rusty so I want new shock mounts as well. Anything helps. Thanks
Fast69Mopar
Here is what I use for the Ram trucks...
