cigarette lighter
dhay13
So my son has a 2018 2500 with the full center console with the cigarette lighter under the phone holder. He travels alot to remote locations so has a few gadgets that plug into these lighter sockets. Anyway, he uses his window mounted Garmin GPS because he has his sites marked in there. The other day it quit working and turns out its that lighter socket. Any ideas what the problem is or how hard it is to replace that socket? Pretty sure he said it was intermittent so wouldn't be a fuse. His GPS works fine when plugged into the rear seat lighter socket
misfit77
Intermittent i immediately think poor connection. Grounds are typical culprit.
Knowing Ram it probably goes thru the can-bus or BCM.
dhay13
dhay13
yeah and with 47,000 miles his warranty is up
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
408 Cummins Turbo Diesel
Both of the center console power points on my truck are intermittent... And both are sloppy "installs". The socket just wobbles around inside the console hole. I'm sure there is a locking nut of some sort behind the console, I just haven't "gotten around to" pulling the console out and fixing them. I'd check and see if your port sockets are nice and firmly attached or if they wobble around in the holes. That would be the first, easiest, and cheapest place to start.
Loudram
Just a sinner saved by grace
Navy Badge
South Jersey
Hemi 6.4L
I'd check the fuses too. Make sure that they are properly seated. Don't dismiss them because it has power. Loose connections can happen anywhere.
dhay13
dhay13
I'll let him know. He just went to Kinzers, PA today for work and probably won't be back for a few months. Took his camper and staying in it
dhay13
dhay13
Well talked to him today and he found that it was actually his GPS cord and not the lighter. He said he had tried it in the rear seat socket and it worked so he assumed it was the lighter socket but he said yesterday it quit working in the rear socket too. So a new Garmin cord is easier to replace than a cigarette socket...lol
