Clunk in the trunk !!!
NorCal Billdo
Ca
Il 6
so all the sudden my truck has a clunk noise in the bed. Seems to happen when I just take off or bumps while going slow. Like the huge pot hole in my driveway. Could it be rear sway bar ? I shook the rear of my truck by hand. Side ways back and fourth and it look like sway was lose so I tightened it. I thought it was good but few days later it was back. Bushings maybe ??
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Known issue, there is a transmission flash to correct it.
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
Bad shocks? Rubber spring spacers going bad? Bad U joint? Bad pinon bearing? Could be many things. I have a clunking/rattling noise with mine that started a few months after we lowered it, kinds like a loose Tailgate. Something is loose back there need to make the time to check it out.
alphaprojects
