Clunk is driving me to drink!
tommyboi87
houma louisiana
5.2 Magnum
Ok. When taking off from a stop or stopping in general I hear/feel a hard ass clunk from the front driver side of the suspension. I've checked and changed most everything. Ball joints tie rods hun bearing, everything. What else could be causing this? Pitman arm? Steering shaft? Gearbox? I seriously need some help guys. I want to take it to a shop, but I never have the time with my work schedule. Taking off work isn't an option, when I get off shops are closed and I don't trust the truck enough to let someone else drive off in it. So ideas, troubleshooting ideas, anything would be great.
Was not sent from an iPhone.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Shocks and springs were replaced when I lowered the front end. How would I troubleshoot the ca bushings?
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
It's feels like it's in my feet when it happens. And it's almost like something moving back and forth until it hits something depending or going or stopping
ohiogrown
ohio
2010 CCSB, 2011 ccsb, 2012 5500, 2016 5500, 2017 ccsb wxpress
4.7, 4.7, 6.7, 6.7, 5.7
I would look at the control arm bushings or possibly a motor mount. Both could transfer through the frame and feel like they're under your feet.
rowdyram
magnum 5.9
I put a large pry bar into the mounting bracket both on the frame and axle. Pry the CA back and forth inspecting for movement or torn rubber. Bright black rubber is an indication of fresh break, tear or crack.
Since it happens while coming to a stop, go to a large parking lot and have someone watch while you stop/ take off.
Look for the wheel to suddenly move rearward while stopping.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Thanks guys. I didn't think to check the control arm bushings. I get off a little earlier than usual tomorrow. So I'll get to check them out tomorrow.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
As for the motor mounts, how would I go about getting those inspected? I don't want to leave anything to guess.
rowdyram
magnum 5.9
For the motor mounts, place trans in drive and power brake it while someone is watching under the hood, then go to reverse looking for excessive movement
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
That's how we verify them at work. :D
bassslayer25
East, Kansas
5.9 360 V8
Have you checked U-joints? Mine were loud AF before I replaced them.
Merc225hp
NA
truck
gas
lol most of what you are being told to check I have already suggested in your other threads. Hope you find it.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
I've checked all but motor mounts and control arm bushings merc. Hard to tell if they're good or bad living alone and not having someone to check for movement. I power break it all the time, I just forgot to have someone looking at the engine. Oops lol
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Will control arm bushings cause a loose-ish feeling in the wheel while steering?
ohiogrown
ohio
Absolutely. They'll basically give you variable caster and camber while driving.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Thanks for that dude. That basically described every bit of the troubles I'm having.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
No no no lol. I was saying that the truck is going to be my reason for drinking.
Merc225hp
NA
truck
gas
Better off smoking a big fatty lol no hangover that way.
tommyboi87
tommyboi87
houma louisiana
5.2 Magnum
Yea, but the. I would want to just eat.. Ok so after further examination, I noticed that the rubber bushing on the upper driver side control arm is falling apart. So I'm assuming that I've located my clunk. So for my next question. I purchased the parts while I was on lunch today. Both sides upper and lower bushings. Now for the question. Is this something that can be changed in my driveway, or will I have to take it to a shop to have the new bushings pressed in? Or, will a big ass breaker bar be enough to wrench them into place?
