James4012
- Feb 27, 2014
- 3
- 0
- 1994
- 5.9 Magnum
Gotta a 94 Ram 2500 4x4 with the 5.9 gas. Has the NV 4500 5 speed tranny. This is my first dodge I've owned, certainly not the first I've used or worked on, but they we're all 12 valve cummins (what I desperately wish I had) Now to me it seems to have a weak clutch (weak to me means I almost have to fully release it before the truck begins to pull) and it groans a bit when I pull off in 2nd or reverse unless I ease off the clutch with minimal acceleration on the gas. Past two days, when I shift up and begin accelerating again it's RPMs climb a bit before it actually starts accelerating. It doesn't loose any moment, just doesn't gain any more. Mainly does it in 5th gear. If I'm doing 70 and romp a bit to pass someone it'll just keep going 70 and simply raise RPM, it has the feel of like the clutch ain't fully released, almost like I'm riding it a bit. Is this the clutch and pressure plate being worn out? or do I have tranny issues? It doesn't whine or chatter any at all, so figure it must be the clutch.
Thanks
Thanks
