Code P0463 Fuel Level Sensor 1 circuit high
Rolin2004
Jacksonville, Florida
Hello, 2012 Ram 1500 Hemi 5.7L. Truck Broke down and gave me a code P0463. After reading the suggestions I went ahead and Bought me a New Fuel Pump out of Amazon cause it was the fastest to arrive. Once I installed the new Fuel pump the truck would start but now the Truck is sputtering. When I put the code reader again now it says Cylinder 1 misfire. What is wrong with my truck? Some websites says pump may not be pumping enough some says fuel pump relay. Please Help!
20092500HEMI
New York
Hello, just going to throw some **** against wall on this one.
I would check the fuel pressure under the hood to see if it’s good. The misfire might be a bad fuel injector. Swap two fuel injectors and see if misfire moves to a different cylinder. Sorry, wish I had a better answer.
jws123
nj
I did both and still have the same problem. I even replaced all the plugs and the coils.
You bought a amazon pump what do u expect?i have leart my lesson twice with both of my rams Oem fuel pump only first time never ran right second time it lasted 4 months.
jimn
