coil pack connectors
tantore
texas
hi guys once again need your help i can not remove the connectors to the coil pack the small tab on the connector will not budge i pull press push no budge please tell me what to do if possible post some pict. 2012 ram 5.7 hemi any help will be welcomed i have the new coil packs and plugs to install once i can remove the connectors than k you in advance for any help
boomer632
Pull up on red tab gently then squeeze connector and pull up. Might have to pry up on connector with screwdriver. I did on mine. On reinstallation put some dielectric grease inside connector to make it easier in future. Whatever you do.. Don't break off the red plastic lock tab prior to getting plug off. I did that on the first plug it tried to change. About an hour later I finally got it off.
