coils or plugs?
2013rammer
Simsboro, La
I noticed just a lil bump will parked today like a small miss could just be me but was wondering how many miles were yall at when yall changed the coils and plugs out im at 65k now
Rlaf75
East Hartford CT
2021 Bighorn
I haven't changed anything yet but changing the plugs will never be a bad thing but i doubt you will need to unless it continously skips. The coils however, aren't really something you have to change unless one does fails. To check coils or detect a misfire you'll need a very good expensive scan tool or take it to a repair shop. I wouldn't worry about it until or if it becomes more pronounced
2013rammer
2013rammer
Simsboro, La
Ill prolly just change the plugs then if i can find 16 of them lol after the new cats exhaust drop in knn and fresh oil it prolly brought the miss out
Rlaf75
East Hartford CT
2021 Bighorn
Is it a steady or constant misfire? Or is it something you felt once idling?
2013rammer
2013rammer
Simsboro, La
just in park and outta gear just felt it after i pulled up back home never felt it while driving
Rlaf75
East Hartford CT
2021 Bighorn
Like I said, changing spark plugs will never have a negative impact, except on your wallet. If it's intermittent then I'd wait a while and see if it gets worse which will make it a lot easier to diagnose the problem if there is one at all. If the truck runs fine and with your current mileage (65k I believe you said?) those plugs should have several thousand more miles to go. It could just be a fluke
2013rammer
2013rammer
Simsboro, La
yeah ill see how she idles in the morning if anything ill see if the dealer has any record of them changing them before and if so how long ago
2013rammer
2013rammer
Simsboro, La
they dont make any aftermarket coils for the newer hemi do they? i knew they did back in 04 and such wasnt for sure bout now
KarL45
Western Slope, Colorado
2018 Ram Express quad cab 4x4
5.7 MDS
Just having an intermittent miss, I wouldn't suspect a coil at all. As for plugs, two things. If you are in the 60k range, your gap is no doubt getting wider. Concerning coil longevity, the farther a coil has to jump a spark the more KV's it will have to produce and will have an effect on it's life. Second, on plugs, am sure that having the plug in a head for many more miles will increase the likelihood of having difficulty in removing them. I probably will change mine around the 50k mark. That said, what brand plug is being preferred for replacement? OEM or other. Not even sure what oem is. Thinking Champion???
BlownGP
Houston/Baton Rouge
You shouldn't need coils for a while. There pretty reliable.
I seemed to have a very very small miss at idle. Like sitting at a stop light.
I change my plugs this summer at 61K and I still feel the miss sometimes.
But my old plugs didn't look that bad and the gaps were all good. I bought the truck used with 33K so I dunno if they were changed before hand though.
I wouldn't worry about it unless it's more consistent and starts to feel really bad.
I would still change your plugs but I really think the 30K interval is almost too soon.
2013rammer
2013rammer
Simsboro, La
Sorry for late reply i went with what orielys said was oem was a autolite doubleplatnium and the side my converter was throwing a code on before i got the cats replaced looked bad some a Lil wet looking even these plugs prolly wasn't the best to get but I didn't wanna spend a tone of money on them and it not change nothing but it helped alot I'll change them again at 100k with a better plug
glsander
