It’s not uncommon, depending on your driving patterns. Was the engine fully up to temperature prior?
There’s always moisture from combustion, in a cold engine it will condense. In a hot engine it’ll boil off and the PCV system will evacuate it.
It is also possible you have something else going on like a leaking head gasket, but if there are no other symptoms besides what you’ve described I would just monitor the situation.
