Confirming Tire Size OK
Kapt
3L
My 2016 Eco with a 2" leveling kit will be OK with 33/12.50/20 tires as long as I use a 1/4" spacer on the front. Right? Just confirming this before I buy them
bchap05
You can run 35s with a level so I'd assume they fit fine. Unless ed changes something I'm unaware of
Kapt
Kapt
3L
Thanks for the reply
OnSale
5th Gen Crew
Philadelphia, Pa
I'm running 20x9 rims with 33x12.50 M/T tires with no lift or level. Stock suspension. No rubbing or hitting on any parts in the wheel well.
I was shocked they fit without spacers or a level kit. But they do.
Sent from my Grand XL using Tapatalk
Eric raugust
Winnipeg Manitoba
I have a 3” lift on my 2014 Dodge Ram 1500 and just wondering if a tire with a true size of 36” will fit on stock 17” rims
Kapt
Kapt
3L
I went and got spacers. I wasn't paying attention and got the wrong ones. So now I have 33/12.50/20 on my truck with the 2" level, and no spacers. It's close, but everything clears
Kapt
Kapt
3L
Even though everything cleared, I got the correct spacers and put them on today. While nothing was rubbing it was extremely close. Ease of mind makes adding the spacers worthwhile I think
Eric raugust
Winnipeg Manitoba
got the 37’s mounted up on the truck and ZERO RUBBING [emoji16][emoji16]
revitupmoto33
Flagstaff
Ecodiesel
Should be fine without wheel spacer, those things are no bueno! I’m running 305/70/17 (34.5”) on 2.8 bils, even at 2.1 only had slight rub on the plastic liner when reverse at full lock
