Did you have the dreaded round knob on dash shifter to start with?? if so what did you need to make the switch? I'm considering this myself have line on nice console with shifter.
Thank You;
awpratt79
Any of the console shifters in a Ram truck up till now have been for a mechanically shifted transmission, the 8spd trans is electronically shifted.Thanks I do have a 2017 1500 5.7hemi with the 8 speed I thought it would be awesome to change over to the console shifter because I found a complete console with shifter and dash bezel for a sweet price.
removed jump seat, install 2013 console with shifter in 2018 2500 Tradesman
It was pretty easy to do, took about 1.5 hours.
Right now I have cheap seat covers and no power or heated seats.Looks good, what seat covers do you have and do you have heated seats?
Probably your best bet to get a console shifter for an 8 spd in a Ram would be to try using one out of a Jeep that uses the same trans. There may be some compatibility issues as the two vehicles may not use the same BCM.
Another option would be to R&D some way for the mechanical shifter to turn a shift dial correctly.
Check www.car-part.com for a console assembly.
That console will work for you, just get a new upper tray that doesn’t have the shifter, then list the shifter on eBay. The rest of the console is the same. unless you were looking to move the shifter.That might be something to look into but was really just asking because I found a really good deal on a console that had the shifter, but turns out it's not really compatible with the electronically controlled 8speed trans. Oh well was worth checking into.
@CincyCuda68 do you have the 66rfe tranny?That console will work for you, just get a new upper tray that doesn’t have the shifter, then list the shifter on eBay. The rest of the console is the same. unless you were looking to move the shifter.
Looks great, a lot of people don't like the space the shifter takes up. I don't see it as an issue, I have the shifter also and that little bit of space mine takes up doesn't bother me!removed jump seat, install 2013 console with shifter in 2018 2500 Tradesman
