OK, now you forced me into long winded mode.
Consumer Reports promises to give you the best bang for your buck and Reliability ratings, anytime someone asks about what the best widget the reply usually is Check Consumer Reports. I'm pointing out that you should take their ratings with a grain of salt.
What else did they get wrong you ask,:sneaky: back in the late 90's the mrs needed a vacuum, now we've had hoovers, electrolux's no problems with either but CR rated the Sharp upright the best bang for the buck and great predicted reliability. 2 months after the warranty ran out (14 months old) the brush bar started screeching and finally seized so I wound up buying the parts & fixing it. the following 2 years other parts broke AND since it wasn't one of the leading vacuum manufacturers we had to drive 20 miles away to find bags for it, not a major problem but an annoyance. turned out to be the worst vacuum we've ever owned. forward to the mid 2000's, looking to by a rechargeable weed whacker. CR rated the black & decker tops. They rated its cutting ability but NEVER mentioned the most important factors with those critters, at least as far as I'm concerned, which was how long the battery charge lasted and how long to recharge. So I go to Lowes & buy it, bring it home, opened it up looked at the manual & find the battery takes 8 hours to charge so if I don't get all of the trimming done with 1 charge I have to wait until evening to finish. Well back to lowes that went. I bought one that CR didn't even list, the WORX which Lowes had a special, get a free battery so 2 batteries (1 hour charge time). still have it, I use that as my edger (has a little wheel to roll on). Forward a couple more years, I was looking for a good cordless drill / Impact driver kit for work around the house. I bought whatever model kit (containing a Drill, an Impact Driver 2 batteries & a fast charger) of Ridgid that home depot had at the time. A few months later I saw ratings by CR, once again NO mention of run time or recharge times in any of the cordless reviews. They had reviews of the kit and of the individual drill & impact driver separately. The individual pieces were both rated tops but the kit containing the same model #'s was rated average????? couldn't figure out what the difference was and they had nothing to say about it. I assumed 2 different people did the single piece versus the kit, which if they're running their business correctly there should be standard test procedures and rating criteria for each device. didn't give me a warm feeling.
