Control arm question
Chrisram2019
Nc
I installed 2" lift coil springs and shocks on my rwd 2019 classic. I had to losses the lower control arm to get them in. I tighten them while it was in the air, forgot about preloading the bushings, so my question is this....when I have the alignment done, will they loosen the nuts to adjust and will this correct the preload on the bushings? Thanks in advance
joshhhh
