Coolant help!
Oscurida
staten island NY
Just need a some advice on what to use for coolant. My radiator fluid hasn't drop any at all but the coolant department has. So was wondering what to use for that. I heard HOAT type ? Which I have no idea what that means.
7777xm
Covington, GA
HOAT, hybrid organic acid technology. This can be bought at NAPA, online, the dealer, etc.
Do not use the compatible will any coolant!
Is your truck running hot? How many miles?
What are the symptoms? Seems a little early in your Rams life to need coolant. A bad ratio of coolant/water can cause a temp increase, but a thermostat would be more likely.
Sent from my Nexus 6 using Tapatalk
BaghRam
If you are a 2011, then it is HOAT coolant.
Two brands that I know of are MOPAR OEM and Zerex G05.
Just ensure you are using actual HOAT.
joshhhh
