Coolant leak
Paul197642
so recently ive discovered that the temp on my 03 has not been what it once was.i did some investigation and found a bit of coolant leaking through the crevice where the bottom bolt is on the power steering pump.its right where the power steering pump bolts to the timing chain cover.i seen another thread on this here and it didnt give me any answers.only leaks after its hot and it a small seep.it doesnt even drip but once in awhile.ive looked all over the timing chain cover and cant find a leak.checked the thermostat housing and hose directly above the power steering pump and checked around the head and i just cant find anything....im stumped.heres a pic of the leak.
P
Paul197642
Im going to assume its just a bad water pump gasket and its leaking down the crevice between the timing chain cover and Power steering pump just above it.
