Coolant sensor issues. help!
RamNation91
Brampton, Ontario
2012 Ram 1500 5.7
need a little help or pointers,
my truck was having issues starting but no engine light or codes when i scanned it. ended up changing the coolant sensor & now starts no problem but my EVIC coolant gauge won't drop below 100F even when i disconnected the sensor. & i believe is it causing bigger issues, transmission seems hesitant while shifting sometimes.
any advice is good advice, Thanks!!
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
maybe a restart on the main computer try disconnecting battery and also tie the neg +pos cable together for 25 mins see if that does anything might set into relearn the main computer
