Coolant temp sensor change
smurfs_of_war
Swift Current, Saskatchewan
This is may be a stupid question, but does anyone know the procedure for changing the coolant temp sensor on a 6.4L? The reason I ask is because I had mine done a few weeks ago and just today noticed the coolant level in the bottle is below Min, and it's always between Min and Max. Just wondering if possibly during the sensor change some coolant was lost and not replaced? If not- may have a leak somewhere that I can't seem to see anywhere.
Sent from my SM-T713 using Tapatalk
WY.Ram
Larkspur, CO
6.4L Hemi
Yes, a good gallon or so will drain when removing your t-stat housing.
2016 RAM 2500 pw | 392ci w 6spd | CAI w ARH long tubes & Solo | Diablo T2 w HF tune | 5.13 AAM w 35" Mickey MTs | Custom Graphics w illegal tint | Dodge Off-Road
smurfs_of_war
smurfs_of_war
Ok, thanks! Didn't realize they had to remove the t-stat housing to change that sensor.
Sent from my SM-G950W using Tapatalk
WY.Ram
Larkspur, CO
6.4L Hemi
Whoa, hey sorry I miss read. I don't think housing has to be removed for the coolant temp sensor, my bad. Apologies. I have my old one sitting in garage, sensor is a thermocouple right down into the housing but it would be very out of sorts to have it pull the housing to change the sensor. I will dble check what Im saying, sorry bout that again.
Statcher1
Kentucky
You should still lose abit of coolant with a T-Stat change. Top it off and keep a eye on it to see if it drops again.
MLNLB
US
Disclaimer: I have never replaced one in a 6.4 [emoji16] However, I have done dozens in other vehicles and they all threaded right Into a coolant passage. So when pulled there will most likely be some loss of coolant. Even when changed at a shop, sometimes an air pocket can get in that just takes some driving to get out. They probably had it filled and after some miles, burped a little air from the sensor change and the level dropped some. Not a big deal as long as it's not actually leaking. Just top it off and keep an eye on it.
Sent from my SM-G950U1 using Tapatalk
Rambojoe
Indiana
It may also have had a small air pocket in it from opening the system that has burped itself...
