JustinH
- Aug 15, 2017
- 34
- 2
- 2002
- Magnum 360
Hello everyone. The radiator blew in my 02 with a 5.9l magnum in it. Driver side plastic tank gave up the ghost. I'm going to be replace most of the cooling part. Radiator water pump t stat and debating if I should go dual 14" e fans. Any recommendations I'll have about 400 to spend on the project. May concern are the pump and radiator. Found a 3 core online all aluminum for 245. Just not sure if I should do a stock or upgrade it. Plan on adding power in future. So far only mod is straight pipe after cat to behind the cab dump.
