Bones1975
- Jul 26, 2018
- 13
- 1
- Location
- Terre haute, IN
- 2002
- Magnum 4.7 v8
Ok so just a little background on what happened. My truck is a 2002 ram 1500 4x4 4 door cab. 210,000 miles on it. It has the 4.7 magnum . It was a very strong hood running truck. I was on the high way an hour into the 2 hour trip home when the seatbelt or in this case warning chime got my attention. I noticed I was overheating so I immediately pulled over. Antifreeze was all over undercarriage. My bottom radiator hose was not connected. I reconnected it filled with antifreeze and water and attempted to start the truck. It had a different sound as it turned over not sureshow to describe but almost a whine. It wouldn't start. I got some starting fluid and was able to start it. White smoke and antifreeze was dumping out of exhaust pipes. I turned it off immediately and called tow truck. I don't know how much is able to leak by with a bad head gasket but the amount coming out of exhaust seemed excessive to me so my gut tells me there is more damage than just the gasket. I guess I will soon find out when I tear it down. This will be my first time down to the heads of any motor so any suggestions, tips, or knowledge would be appreciated. Thanks guys
