Timsdually
The old saying..."Never say 'never'"
I saw that all the time back in my GM Tech days. The first year of the LS powered Trans Ams were hitting the market. (1998)I wonder what they'd do if a truck comes in for this "recall" fully deleted? If/when my emissions equipment goes that's the route I'll take. The dealer has never cared in the past since my trucks have all been out of warranty and we don't have emissions testing in Alabama. As an aside, I won't be getting this recall done anyhow.
Overwriting an aftermarket tune is as easy as replacing a defective factory tune with a new factory program.In my specific scenario, I don't own any vehicles in warranty.I assumed that they wouldn't be able to reprogram my ECM anyhow since it would not have the stock programming on it but I don't want to risk them trying to overwrite the tune on it.
That's all I had to do on those Trans Ams.
Yup and once they overwrite it, it is gone! It is cleared and written over with the new. So if a dealer does the update, you have no way of retrieving the tune. It leaves you begging the tuner to get another copy and that usually involves exchange of monies.
Um, I have access to my current tune (and dozens of others from my tuner) at my fingertips. The dealer can over write it, I can re-load my tune a few minutes later in their parking lot and drive away, it's as easy as that.
I'm referring to VIN locked tunes. For example some tuning hardware "Marries" to the VIN stored in the PCM. If you have an agreement with your tuner or your own laptop with software you may like in your case.
My tunes are VIN locked....
You clearly don't understand how modern tuners work. I can reload them from my phone all day long.
HP tuner are a little dated (but they are working on catching up)
I use EzLynk, but EFI live can do the same thing, it loads from a device vs the phone though. Those are the 2 most popular tuning platforms (and have been for several years).
I'm sure they word it as "defeat devices" is make it sound more dramatic. As mentioned it's not a physical part it's software that running the engine/emissions.So what does the 67A emission recall have to do with the alleged types of installation of defeat devices? It may just be the timing of the 67A emissions "PCM" update that people are thinking it's related to the Cummins 1.6 billion fine.
Could be. It does seem a bit premature, since the final settlement has not been approved yet. And the recall is only for 13-18's, while the 20-23's are mentioned in the press releases also. Time will tell, I guess.It may just be the timing of the 67A emissions "PCM" update that people are thinking it's related to the Cummins 1.6 billion fine.
I've seen youtube video of guy that had it done and then test drove with pulling trailer with 9,000lb tracker up grades for 150 miles and found no change in power or milage. Some think it's just a software update, but the recall states it's an "upgraded calibration".
That's just it, no one will tell you exactly what the upgraded calibration consist of doing.If the recal r*e*t*a*r*d*s fuel injection timing to reduce NOx into the SCR exhaust reactor, your fuel mileage will suffer.
