Curt reflex brake controller issue
socalledchad
I picked up a curt reflex a few months ago...it works well..the issue I have had with it is it also engages the brake when I accel...after I get to speed it goes back to .06 volts...but it will go as far as 2.5 volts when I accel and about 3 or 4 volts when I brake ..I believe I have it all set up correctly ..anyone have this issue
csuder99
Sounds like the connection from the brake light switch has always power and the controller is always activated. Double check the connections...
