Custom rotary shifter
VA-RAM
STL, MO - Norfolk, VA
2017 Laramie / 2020 Laramie
Looks nice! Does it attach will the old dial screw? Thank you
Actually, no. It is a solid piece of aluminum. caulk04 machined it with such close tolerance, that the hex hole in the back, pushed on the hex stem with some effort and does not budge...YYMV. He thought I might have to use a thin piece of plastic bag or two or something to make sure it was tight, but no issues at all. Quality work.... and it is not permenent...it will pull off, with a bit of effort.
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
I’m about ready to find me something else or remove my Mopar sticker because I just never thought it would be such a problem never forgetting to put the trans in Park before shutting the truck off and even though that shouldn’t be a problem, the reason it’s a problem is since the auto-park puts it in park automatically if you shut the truck off without putting it in park, now you gotta purposely keep doing that like seven times so that you get the orientation back around the right way.... makes it much easier to be habit forming....lol.
Update....
I went ahead and peeled my cool Mopar sticker off so now it’s just the regular ole gear with the B&H shifters logo.
caulk04
Supporting Vendor
No, I left them raw so they could be finished otherwise, if so desired.
Jim Marrs
Galveston
I would love something other than the buttons on the steering wheel to select individual forward gears.
