cyl #4 misfire, help
cabrio85
4.7l
ok pulled codes for camshaft sensor and cyl #4 misfire. changed cs sensor, switched coil packs, and spark plug. no code for cs sensor, still one for misfire, so switching coil packs didn't change anything.
any ideas where to look next? need to get it inspected ny end of the month.
04 ram 1500 4.7l
wickedwhite2012
Baton Rouge
I think you in the wrong forum. But when you changed cam sensor and coil packs. Did you delete the codes after??
ericlee9386
k swap injectors next a compresion test and check thle valve springs. The intake my have a vaccum leak so check that as well.
C
cabrio85
4.7l
thanks, gotta make time for that.
