D-150 225 slant six NO SPARK
Aaron83d-150
Clear Lake Wisconsin
225 Slant Six
My d-150 has no spark I put in points, cap, rotor, wires, coil, ballast resister. And it fired right up and ran. Then the ballast resister started smoking and stopped working and the coil died, what would cause this to happen
Fast69Mopar
Without seeing the truck or knowing any more information I would say that since the ballast resistor went
Tango Uniform it took the Ignition Control Box with it.
It's mounted to the inner fender or the firewall in most cases and has a triangle-ish shaped connector with 7 wires in it.
Aaron83d-150
Aaron83d-150
225 Slant Six
I don’t know if it has it. Someone cut out all the electronic ignition and put points back in it.
crazzywolfie
under the truck
switching to points might have been someones solution to lean burn ignition. electronic ignition would be better. it does sounds like the ballast resister failed. if it failed again i would definitely be looking for a cause but if it is fine it might have just been a faulty ballast resister.
pacofortacos
Did you replace the condensor along with the points?
ameer73
