Multiple misfire and no spark on two cylinders (2003 5.7)
Knuckles
wi
I have found a lot of dead end looking for info on my problem and might have it figured out. I need some verification and help making sure I didn't miss anything.
My truck is a 2003 5.7l 4wd. with just under 150k miles
The problem started out as a PO357 while driving on the highway but still running fine. I bought some new NGK copper plugs and a set of denso wires. Gapped them and put them in. Plugs were very worn and electrodes were rounded off.
I cleaned up the connections on the coils where the spring is inside the boot and put some dielectric gel on them. I then swapped no. 7 and no. 1 coils incase 7 was bad since it is a lot easier to get to if this didn't solve my problem.
This made things worse. I then had codes PO300, PO351 and PO237.
I bought 2 new delphi coils because it was cheap and easy. I cleaned all grounds and replace positive and negative battery cables. Put them in with no change.
I am getting odd readings on the coil from pin to pin. I think I need a new meter but will "barrow" my fluke from work tomorrow to verify. The are inside coming up to temp. (in the 30s and snowing today)
Then I started looking for info on the problem.
I inspected connectors at coils and pcm and they all look fine. I have continuity on from coil connector to pcm connector (wire not broken) and nothing from coil connector to ground (not shorted).
I unplugged the 2 problem coils and put a spark tester on no.1 and nothing. I then put a noid light on the plug for no1. Turned the key and it started up but ran better then it did with the coils plugged in. I forgot to pull the fuel pump relay. The light lit up solid.
I think my old no.1 coil and the two new ones are still good.
To me it seems like the no.7 coil went bad and fried the pcm driver. When I swapped that coil to no.1 it then fried that driver.
Does anyone have any thought / comments or other things to test before I start looking for a pcm. I don't have a scanner to program it and was at my local scrapyard yesterday and check 15 different trucks and all had the pcms taken out already.
kevkev
SRST,FL
Definitely scan it and see if the driver is fried. Happened to me on my number 7 coil. Actually melted the coil.
Sherman Bird
Houston, Texas
P0351 is a primary ignition control circuit code for #1. Changing plugs/coils for this code is done after testing diag tree says to. Make sure that your cylinders which misfire have good voltage at the coil for that cylinder.
K
Knuckles
wi
Thanks for the replies. I changed plugs and wires because they were past due. I swapped the coils because they were dead. I have good voltage to the coils that are not firing but it is not pulsing. I ordered a pcm from flashmasters and a set of new coils. The number 7 coil must have failed and burned the coil driver. They were all original and rust was causing the laminated core to swell up.
OTownRam
