Dang squeaky door hinge
tomb
ontario canada
2012 bighorn-cherry red
This is false, fluid film do not cause rubber to swell. It's perfectly safe for rubber.
If you dont believe me- read the small print on every can (every can I buy in Canada anyway) Why would I make that up, I love the stuff!!!
Gixxer750
N. Idaho
2015_2017
will need to try that! thank you
I've had only gotten weeks out of the 3 in 1 slide lube, wd 40 white lithium, and a couple months and big mess from tubed marine grade white lithium grease. And same frome graphite.Im eyeballing the liquid molly but to hell with that price tag, unless
uncle527
I found that the squeak on my 2014 was coming from the spring itself (binding). I rubbed lithium grease all over the springs and the noise stopped.
