Dash display troubles
DMAX414
Wimberley, Tx
V6
2019 next gen Laramie. Dash display comes on randomly and will stay on. Once truck is turned off and doors are closed, display will usually timeout as normal, but will come back on later. Tried disconnecting battery cable and resetting computer memory to default under settings app. Does anyone have an idea?
MarshRam
2014 SLT 4x4, 2012 ST
First easy step is FOB proximity. Is it close to the truck. A faraday bag usually solves this. I did read about a guy with this issue, he tested faraday bag, negative battery cable and the battery itself for parasitic draw. Turned out he had his phones blue tooth connected and that was waking up the truck. He just disconnected blue tooth from the vehicle when not in use and problem solved. A few starter options for you to explore. Good luck!
Clubcar
