Dash removal
CherryRed
South West Virginia
I haven't cracked into one myself. However, from the few things I have done, such as removing the door panels and the trim around the center stack, it appears these trucks are real easy to work on. Modern CAN bus has reduced some of the wiring. I bet with a few basic hand tools and a couple hours, you will be looking at that AC evap. Be careful with handling the airbags. be prepared to replace the engine coolant if you have to disconnect the heater core.
