Dash speakers
ivey_usmc
Austin ,TX
I have the base model audio with the 8.4 display. I want to change the dash speakers and add a center speaker. Does anyone sell 3 dash speakers? I dont want to buy 4 or just replace 2.
Witch
Hemi 5.7 liter
I bought two pairs and as soon as I posted a thread about it the extra one sold
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
There is a Mopar kicker upgrade kit with 3 dash speakers & 2 6x9's. Not sure if there's wiring for the center speaker on the base 8.4 radio trucks (vs with the Alpine amp).
@Graygoose probably knows.
Mopar Kicker Audio System Upgrade Package - 77KICK42 (frt w/3 dash) https://www.amazon.com/dp/B00JPRBKR6/ref=cm_sw_r_cp_apa_C3PvzbGWCNZWW
Or
2013 Dodge Dart Kicker Speaker Upgrade 77KICK28AB (w/2 dash tweeters) https://www.amazon.com/dp/B008I33J40/ref=cm_sw_r_cp_apa_j6PvzbFKS38PM
Or
2009-2012 CHALLENGER KICKER SPEAKERS MIDBASE MOPAR 3.5 6X9
77KICK11AB*(w/2 dash spkrs vs tweeters) https://www.amazon.com/dp/B005LH0X9K/ref=cm_sw_r_cp_apa_u7PvzbJ3EQ71E
Mopar Rear Door Speaker Upgrade - 77KICK41 (2 way) https://www.amazon.com/dp/B00F6E24BI/ref=cm_sw_r_cp_apa_o4PvzbYNG5QP8
M² Mods - From my non Flammable S7!
TomT
SoCal/OC
How are you going to wire the new center speaker? You would need some type of processor to get a real center channel signal.
ivey_usmc
ivey_usmc
Austin ,TX
Thinking of tapping into one of the front dash speakers for the center
Kapt
3L
If you're going to do that, wouldn't it be better to tap into both? + from one and - from the other? Wouldn't that give a more centralized sound for the center?
TomT
SoCal/OC
That would ruin your stereo image. You would basically have two lefts or rights.
I guess if you were going to do it anyway, you'd want to tap into the right dash speaker. At least that way the driver's seat would still get a normal left/right stereo mix. The passenger, however, would be getting all right side.
Of course, if all you listen to is talk radio or podcasts then it wouldn't really matter. :roflsquared:
Tom
TomT
SoCal/OC
I'd be worried about that causing some weird electrical loop or something. Not sure how the head unit amp would deal with that.
BadHabit2Break
Houston, Tx
3.6L
I wonder if those Kicker 3.5's are 8ohm? If they are 4ohm, they are going to be overpowering the rest of the system.
Spanka
Cummins
Is it just the Alpine system that is 3 ohm? I put 4 ohm Hertz in my dash.
BadHabit2Break
Houston, Tx
3.6L
The Alpine is a different animal.
I have the 6 speaker setup and the doors are 4ohm and the dash speakers are 8ohm. There is no center channel speaker.
The dash speakers in the base audio system are crossed over using a 2.2uf capacitor(right on the OEM speaker). If you replace it with a 4ohm speaker, your head unit has a 2ohm load for the fronts.
WilliamS
Tampa FL
You cant just add a speaker, you will need something to help with that load. The base 6 speakers are setup a certain way to keep the dash from over powering the doors. Im adding a center but Im also adding an 8 channel processor.
A good set of speakers in the dash can change the image in either direction good or bad. The wrong impedance will mess up the 6x9s in the doors real bad and you will lose a huge amount of low end.
This is not a great place to do it wrong.
13 Ram 1500 5.7 hemi
SLT Outdoorsman
When i looked at the rear door kicker speakers it says front door. I have ra3 radio with 6 speakers, so I would get both kits, the two 3.t with 2 6x9 for front, then the 6x9's for rear door, just to confir. Rear doors are also 6x9, and not 6.5 round?
Get the 77KICK28AB for the fronts and the 77KICK41 for the rears
If you run the 77KICK42 up front, when turning the volume up, the head unit can overload and shut down.
